The "1.7" is revision 1, iteration 7. Every time you check in the model in the current revision, it gets the next iteration number.
The "+" means that the model in your workspace has been changed from the "1.7" model in commonspace.
When you save your changes and check it in, it will become "Rev: 1.8".
Hope this helps,
Arnold
