Community Tip - If community subscription notifications are filling up your inbox you can set up a daily digest and get all your notifications in a single email.
X
Pro E users, I have a file name display question. On the top window bar, the display is: <file name="> (Active) - Pro/ENGINEER and on others , the display is: <file name="> Rev: 1.7+ (Active) - Pro/ENGINEER (this is an ex. the rev. # varies) What does the " Rev: 1.7+ " mean ? Brad WF 3
The "1.7" is revision 1, iteration 7. Every time you check in the model in the current revision, it gets the next iteration number. The "+" means that the model in your workspace has been changed from the "1.7" model in commonspace. When you save your changes and check it in, it will become "Rev: 1.8".
