Gurus,
We are having a bit of a discussion with the use of publish geometries
for cores/casting/machining. The discussion centers around whether the
geometry will update without the assembly it was created in, in session.
I just ran a simple test and if I create part1 with a published geometry
at the end, then create part2, and external copy geom the part1
published geometry into part2 WITHOUT an assembly, then if I open part2
from an empty session, it brings part1 into session too, and thus
updates with any changes in part1.
Now if I do this in an assembly, then open part2 from an empty session
it just gives me warnings about the assembly not present and won't let
me edit the copy geometry either...
IS there a config.pro option that would force the first behavior for
both situations? What we would like is to not loose that reference,
even if we created things in an assembly and no longer have the
assembly...
thanks in advance...
Paul Korenkiewicz
FEV , Inc.
4554 Glenmeade
Auburn Hills, MI, 48326-1766
