installing on desktop when already installed on laptop.
ptc-2515740
I originally installed on laptop but have since got a faster desktop and would like to install on that instead. Is there a way to switch physical address so I can install on Desktop? If I need to remove it from laptop, that is fine. thanks
You need to request a new license file from PTC. There is no way change the address such that the license will work. Basically you are asked via the on-line questions that you have removed the software from the laptop prior to installing on desktop.
