Is there a config option to be able to see all the messages that appear in
the message line during computing the CL data? When I am working on a big
program and computing the CL data for posting or Vericut. I sometimes see
errors or processes that ProMAN is doing but the lines move so fast
sometimes that I can not read what it is displaying. When Pro is done
computing the CL data I can only scroll up a certain amount of the message
and not all that has been done. So I usually go back thru each section of
sequence and redo so that I can see warnings and errors.
I would like it if it was able to spit out a text file or xml file so that I
can scan thru them and make sure there is no mistakes.
Thanks.
Son Nguyen
Tooling Designer & Programmer
785-667-7763
108 W. 2nd Street
Assaria, Kansas 67416
