search_path does not work
ptc-2486294
I'm trying to use search_path in config.pro file but it doesn’t work. I don’t know what is wrong because when i add search_path to my config.pro flie it is working until I switch off proe. Next time I start proe i have to go to tools options and open config.pro file to make it work(otherwise i won't be able to retrieve files from other folders). Config.pro should load everything automaticly but for some reason it ignores my search_paths. My config.pro file is inside ...proe...text folder. can somebody tell me what to do to fix this problem?
Artur, Does you search path file contain any spaces in the path? ProE does not recognize any spaces in the path name. For example these are correct paths: \\Mspserver\NPD\PROE_FILES\PROE_COMPONENTS\SCREWS \\Mspserver\NPD\PROE_FILES\PROE_COMPONENTS\CONNECTORS \\Mspserver\NPD\PROE_FILES\PROE_COMPONENTS\EXTRUSIONS \\Mspserver\NPD\PROE_FILES\PROE_COMPONENTS\O_RINGS \\Mspserver\NPD\PROE_FILES\PROE_COMPONENTS\INSULATORS If you are using, for example "My Documents" in the path, ProE may not recognize it. Hope this helps
Thanks very much. It helped indeed
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
