xtop.exe - background mode - option to ignore conflict when loading model
cc-2
we have an application which download file from Windchill, load them into xtop.exe in a non graphic mode. This is what I call the background mode.
We have noticed that some of the models cannot be loaded. When we open those models manually using ProE in a graphic mode, the user is asked to take an action (ignore conflicts, check out/continue/read only etc.... this type of messages).
We have also noticed that the Windchill Publisher also loads the models in a non graphic mode but it does not have any issue in loading those models.
I am wondering if there is a type of config or option we need to use to tell xtop.exe something like.
"If conflict, take default option and carry on"
Do you know what I mean ? Have you experienced this before ? Does such config/option exist or is it reserved for the Windchill Publisher.
Thank you in anticipation and have a good holidays
best regards
0 REPLIES 0
