CLI: --showReferences results in MKS124819: Invalid option: "showReferences"
AnitaD
8-Gravel
I simply want to list all objects (queries, charts, reports) that reference my dashboards...  Anyone!?
awalsh
(To:AnitaD)
The documentation is wrong for this command. The --showReferences option will not work. You also can't see the References column for Dashboards in the GUI.
The only way I've found to get a list of the queries, reports, and charts used in a dashboard is to look at the Layout.  You can look through this in the GUI, but I find it easier to search the xml directly.
You can get the XML output for the dashboard layout with this command:
im viewdashboard --showlayout [dashboard name]
Within the XML, search for QueryLink, ReportLink and Chart.  You may also find references in a URLLink.
For example:
                <Chart filtered="True" name="Open Items - Team"/>
                <QueryLink filtered="True" name="My Open Items"/>
               <URLLink
                         href="http://[server]:[port]/im/ci.rundashboardview?mks.webapp=default&amp;selection=__id1864"
                         text="Global ILM Dashboard" textStyle="Hyperlink"/>
                 <ReportLink filtered="True" inline="True"
AnitaD
8-Gravel
(To:awalsh)
I appreciate the reply, awalsh.  Still, can't help but hope that the CLI commands that indicate that references can be outputted (per the documentation) will one day work.
