Creating field from existing one in Windchill RV&S Administration
SM_10187717
6-Contributor
It would be convinient if Fields definitions could be copied like Type definitions.
Today when I need to create a new field which is quite similar to one I already have and since there is no "Copy Field..." function I have to create new Field and copy carefully all the setting manually from original Field.
0 REPLIES 0
