Get default cache values for SIRootCache
hbock
I encountered repeated ocurrrences inServer error log in PTC Integrity (RV&S) 11.1:
Cache Warning: SIRootCache: Two successive cache collections in less than 60 minutes ( 0 minutes ).
The support article CS115377 shows a solution to increase the size of properties, but I do not have the currently active property values in the configuration file "is.properties" to calculate the increase (they are not contained).
How can I retrieve the actually used property values?
<Server Installation>/config/properties/si.properties file
si.ServerCache.default.bulkMemSize=<new_memory_size_in_MB>M
si.Cache.default.bulkDiskSize=<new_disk_space_size_in_MB>M
0 REPLIES 0
