Hello
In PTC Modeler 10.2, is there a way to copy to the clipboard the token so that it is ready to paste it in text fields? If not built-in, is it possible to write a script to do that?
The need is to replace drag-drop from pane to text that could be annoying with long panes.
The need is not to copy the model element but its token as used in text fields (like Description of requirements, ...)
I haven't any command in the IDE.
I looked at Automation API of model elements but haven't found any clipboard-related operations.
Dumping the content of the clipboard after copying a token gives internal info that is maybe not appropriate (as too much linled to internal PTC Modeler deisgn):
=== Available Clipboard Formats === [49161, 49293, 1, 16, 7, 13, 49171]
I guess PTC Modeler uses custom types [49161, 49293 and 49171] to store internal bytestream representation of the token that could be pasted.
Thank you for your support
Thinking again on this topic, considering the content of the clipboard, I tested a simple:
1. copy/CTRL+C of the model element
2. paste/CTRL+V in a text field
... and it works as expected: a token is created in the text field.
A nice simple solution 🙂
