SysML Use Case Properties Pane is Missing Standard Use Case Specification Properties in Text Tab
SP_10284629
2-Explorer
Apologies in advance, if this is not the correct place to post a question against Windchill Modeler (v9.3)
When I select a SysML Use Case and then view the Text Tab in it’s Properties Pane, I can only see pulldowns for the Intent, Description and “Alternate Courses” properties. Per the Use Case (Dictionary item) supported properties, it’s missing the “Post Conditions”, “Pre Conditions”, “Timing Note” and “Visibility”. How can I include and populate these missing properties?
Thanks for any help!
0 REPLIES 0
