Unable to set target path to document links while importing file to IBM Doors Database in JAVA API
MichaelPantke
3-Newcomer
In Remote API  reference document page 17 topic 'Define path to document and links'. here
I am using PTC Integrity Requirements Connector (IRC) v 3.4
While importing document ( xml and reqif files into doors database) I am trying to set Target-Path for links (of document).
// check document in the configuration and set the target path
IRemoteImportDocument[] docs = configuration.getImportDocuments();
for (IRemoteImportDocument doc : docs){
doc.setTargetPath(targetPath);
doc.getRelationGroups()[0].setTargetPath(targetPath);   // here I am not able to set the path , I am getting error :
Exception : com.atego.exerpt.exchange.remote.communication.core.DisabledException: The option 'target path' of import relation group 'DOORS Links' is disabled and cannot be changed.
2020-03-03 11:26:00 ERROR - Failed to import documents.
0 REPLIES 0
