There are a lot of predefined reviews in Reviewer; most of them are around UML. When checking system models, I often use the SysML <<problems>> to indicate that there are things where it would be good to have a deeper look.
You can find problems in the Requirements Browser, and going through them, you can find the annotated elements in the properties of the problem.
However, I find it useful to have Reviewer checks as well when using <<problems>>. One custom review published here is showing all problems not connected to anything, and the other shows all elements annotated to a problem. Using both reviews, problems are fully covered in my mind. I've attached the reviews here, which can be placed in the User-defined folder of Reviewer. Before, change its extension to *.rev.
Example: In the HSUV model, I added an unconnected problem to the requirements diagram:
There is another linked problem already in the HSUV example model:
The new reviews lists both problems according their nature:
