how to see issues that impact other projects?
Cosmina
Does someone knows if it's possible to create a query to  see all issues in certain state , from certain projects, that impact another project/projects (if possible to select the impacted one) ?
awalsh
(To:Cosmina)
If you have a field that gives the other impacted projects, then you could search on that field, and state, and use the project filter to limit to only certain projects. You can also include the project field in the query rather than using the project filter.
3 REPLIES 3
awalsh
(To:Cosmina)
kjain-2
(To:Cosmina)
Hi Cosmina,
Before moving forward i would like to know how you are capturing Impact ? Like on what basis system can know this issue is gonna impact another Projects ?
Kapil
Cosmina
(To:kjain-2)
Hi Kapil,
I was interested if an issue impacts some specific projects.
In this case I created a query where I selected Relationships filter -> Impacts -> Project (here I selected the projects that I am interested on).
