Hi Team,
Following im issue CLI command string works in cmd line not with Python sub process :
CLI Command works in CMDLine:
im issues --queryDefinition='((field["Project"]="/L2H0090") and (field["Document ID"]="11601660") and (field["Status_fld"]="reviewed","released","approved") and (field["Category"]="Software Test") and (field["External ID"]contains"Fully_Automated"))'
import subprocess
string = "im issues --queryDefinition="+'((field["Project"]="/L2H0090") and (field["Document ID"]="11601660") and (field["Status_fld"]="reviewed","released","approved") and (field["Category"]="Software Test") and (field["External ID"]contains"Fully_Automated"))'
try:
result = subprocess.check_output(string)
print(result)
except subprocess.CalledProcessError as e:
print(e.output)
Its showing below error:
*** The query and queryDefinition options are incompatible with an issue selection.
Please support here to get correct command string which shall work in python as well.
Thanks in advance.
Article - "How to define a "query definition" that contains a field with spaces via CLI in Windchill RV&S": https://www.ptc.com/en/support/article/CS153138
