Add an older version using As Stored dependencies
Rami_Noah
Hi
i'm trying to build an Creo utility that adds "non latest" version of epmdoc to WS.
Unfortunately, this is not supported through the toolkit - as specified in Article - CS7762
So, i'm thinking to add epmdoc to WS using Windchill api first and then connect to relevant WS using Creo API.
did any of you tried this approach ? any other suggestions/ideas ?
i'm planning to facilitate  AddToWorkspaceAction for that.
Many thanks,
7 REPLIES 7
avillanueva
(To:Rami_Noah)
What is the ultimate goal? Are you trying to load data and control some pre-existing as-stored history? I have not tried this approach but it is possible to load older iterations and versions to a workspace. The normal UI allows for download of non-latest versions but there will be a check to verify you want to replace the existing version if it already exists in the workspace. Seems like a lot of work, especially if you want to use this all the time.
Rami_Noah
(To:avillanueva)
I'm implementing now DrawingValidator byElysium Software, which is btw great product for comparing drawings & geometry, and though it would be VERY beneficial, process vise, to add the drawing comparison result to promotion/ECN approval process. so the approver can see the report and skip the tedious process of looking for the changes.
in order to do the comparison i need to get the previous RELEASED/APPROVED version of the model/drawing, and comparing it to new one.
Getting the new one, latest, was quite easy. however, getting the old one seems like a real challenge...
and here i'm looking for the community assistance
What if you published a PDF at each release, then just compare PDFs? I would think it would be easier to manage 1 PDF for future comparisons then trying to get all the correct references historically.
Rami_Noah
(To:joe_morton)
using pdf for comparison is lacking the functionality existed in DrawingValidator byElysium Software which we found to be superior to any product/method out-there.
BTW, as we intent to create their special format, EPF, on each check in, in the future we will use your technique. however, there is still a gap of 2-3 year by then...
HelesicPetr
(To:Rami_Noah)
Hi @Rami_Noah
Check the wt.vc.config.ConfigSpec interface
there is a subclass wt.epm.workspaces.EPMAsStoredConfigSpec that can be used for the query
here is example how to use it
EPMDocument epmDoc = null; // null is just for usage purpose you need to search your assembly iteration to get as stored config.
List<ConfigSpec> configSpecList = new ArrayList<ConfigSpec>();
EPMAsStoredConfigSpec epmAsStoredConfig = EPMAsStoredConfigSpec.newEPMAsStoredConfigSpec(epmDoc.getAsStoredConfig());
configSpecList.add(epmAsStoredConfig);
QueryResult qr = ConfigHelper.service.filteredIterationsOf(epmDoc.getMaster(), configSpecList);
PetrH
Rami_Noah
(To:HelesicPetr)
thank you for you suggestion.
i'll verify that soon
Rami_Noah
(To:Rami_Noah)
you can see below the relevant code :
       public static WTCollection collectItemsForWorkspace(EPMDocument theDraw) throws WTException, WTPropertyVetoException {
              WTCollection myResult = new WTArrayList();
              // Definitions/setup
              WTCollection seeds = new WTArrayList();
              Collection<?> result = new WTArrayList();
              EPMDocConfigSpec configSpec = new EPMDocConfigSpec();
              configSpec.setAsStoredActive(true);
              NavigationCriteria nc = NavigationCriteria.newNavigationCriteria();
              List<EPMDocConfigSpec> configpecs = new ArrayList<>();
              // Collect Items
              seeds.add(theDraw);
              logger.debug("Seed is: "+theDraw.getNumber()+" "+theDraw.getName());
              EPMAsStoredConfigSpec asStored = EPMAsStoredConfigSpec.newEPMAsStoredConfigSpec(theDraw);
              EPMDocConfigSpec epmAsStoredConfig = EPMDocConfigSpec.newEPMDocConfigSpec(asStored);
              //Bug Correction for EPMDocs that does not have As Stored Config Spec - PTC Case C12869402
              if (asStored == null) {
                     configSpec.setLatestActive();
                     configpecs.add(configSpec);
                     logger.debug("Seed is: "+theDraw.getNumber()+" "+theDraw.getName()+" LATEST Config Spec");
              } else {
                     configSpec.setAsStoredConfig(asStored);
                     configpecs.add(epmAsStoredConfig);
                     logger.debug("Seed is: "+theDraw.getNumber()+" "+theDraw.getName()+" AS STORED Config Spec");
              // Navigation Criteria
              nc.setConfigSpecs(configpecs);
              // Collect items
              //CadCollectedResult ccr = CadCollector.newInstance(seeds, nc).dependents(GatherDependents.ALL).familyGenerics(GatherFamilyGenerics.ALL).familyMembers(GatherFamilyMembers.ALL).drawings(CadCollector.GatherDrawings.ALL).collect();
              CadCollectedResult ccr = CadCollector.newInstance(seeds, nc).dependents(GatherDependents.ONLY_REQUIRED).collect();
              result = (Collection<?>) ccr.getCollectedObjects();
              logger.debug("collectItemsForWorkspace - Number of objects Collected : " + result.size());
              for (Object obj : result) {
                     logger.trace("collectItemsForWorkspace - obj: "+obj);
                     if (obj instanceof EPMDocument) {
                           EPMDocument epm = (EPMDocument)obj;
                           logger.trace("collectItemsForWorkspace - collected: "+epm.getDisplayIdentifier());
              logger.debug("collectItemsForWorkspace - Added Collected EPM Docs");
              WTCollection addedItems = new WTArrayList(result);
              //result.addAll(partResult); - this collection gets Object Reference
              Iterator<?> items = result.iterator();
              while (items.hasNext()) {
                     Object item = items.next();
                     if (item instanceof EPMDocument) logger.trace("collectItemsForWorkspace - Related CAD object : " + ((EPMDocument)item).getNumber()+" "+((WTObject)item).getDisplayIdentity());
                     if (item instanceof WTPart) logger.trace("collectItemsForWorkspace - WTPart object : " + ((WTPart)item).getNumber()+" "+((WTObject)item).getDisplayIdentity());
              myResult = addedItems;
              return myResult;
