Hi Team,
I'm trying to achieve a routing based on attribute value.
Scenario.
Depending on the context name in which ECN is created it should take the defined routing path.
Tried referring CS129817, unable to get thourgh.
Any references /help would be appreciated
Please show us the code you have now and information about the IBA. What is posted in that article should work. Also screen shots of your workflow conditional. Best practice is to have this code in an external class method can reference that in the workflow.
CS129817 is working.
Good.
For lazy people please use a link 😄 CS129817 - Workflow routing based on soft attribute value in Windchill PDMLink
PetrH
