Can we create DocumentUsageLink via API or do we need custom Java Services?
AS_14348618
Version: Windchill 12.1
Use Case: Scenario is the bulk loading of document links seeing if this can be achieved through WRS or needs some customization.
Description:
Unable to find any OOTB WRS Services in Document Management Domain to achieve creating DocumentUsageLinks for linking of documents.
TDT
(To:AS_14348618)
Hi @AS_14348618,
It needs to be customized.
Following is the API to create documentusagelink.
WTDocumentUsageLink.newWTDocumentUsageLink(document,documentMaster);
Hi @AS_14348618 ,
By extending DocUses domain you can enable DocUsageLink creation, as of now it supports reading structure of documents.
Copy Paste DocumentUsageLink.json and js files to custom folder following same hierarchy then update json to include Create/Update actions
"operations":"CREATE,UPDATE,DELETE",
Use hook methods processAdditionalAttributes, saveObject  to create link between objects
use below references
https://<windchill server>/Windchill/netmarkets/html/wrs/jsdoc/index.html
Processing HTTP Requests for OData URLs
Hi @AS_14348618,
Anurag
