Change name Server Address
MS_Santos
Hello
Would you have to change this name of the Windchill server? or do I need to change the server again? for the little that he took the name of the server I put.
TomU
(To:MS_Santos)
Edit:
You don't need to rehost or use a reverse proxy if you want to access the Windchill server from a different domain name / URL.  In that case you just have to change the wt.server.codebase property.
Article - CS178849 - How to make Windchill use a DNS alias when generating URLs in Windchill (ptc.com)
You will need to go through a rehost process if you need to change the actual physical server name for some reason.
5 REPLIES 5
HelesicPetr
(To:MS_Santos)
Hi @MS_Santos
You need to follow rehosting process.
Here is a article for Rehosting utility how to change server name - you should follow the rename scenario
CS162685
Here is a knowledge hub with others articles describe the rehosting
CS357522?
PetrH
@HelesicPetr , great post. Some addition things I've picked up along the way:
  • Never use hostname of server as web address. I always pick a friendly name and does not interfere with IT naming conventions for hosts.
  • Choose a very generic internal hostname for installs. Alter to users using reverse proxy server. This allows you to changes names if company name changes (I've been through a few) and makes cloning for new environments a snap. Only need to change name in a few places. It also has the advantage of decoupling old LDAP branches from hostname (not in IE conf files).
  • Make sure your installs cannot see or talk to each other (prevent cross talk between different installs). This can be done in HOSTS file.
Hello
But how do I change this now? before I was using outside domain, And setting HOSTS file for machines to access this, has easier way to change this name or better change server name?
I also recommend @avillanueva's suggestion of a proxy in front with a friendly name. The article referenced shows how to set up Windchill behind a proxy. The property you are looking for is wt.server.codebase
xconfmanager -s wt.server.codebase="$(wt.webserver.protocol)://<<YOUR FRIENDLY HOST>>:$(wt.webserver.port)/$(wt.webapp.name)" -t codebase/wt.properties -p
https://www.ptc.com/en/support/article/CS68466?source=search
TomU
(To:MS_Santos)
Edit:
