I have to create a check box in the change activity with string type and until the check box is ticked the complete task button should be disabled. please find the attached image for reference.
for creating wf variable here, should it be boolean variable or string variable? and in the display name i need that sentence which i had attached in the image, can you please tell me how to get that?
It looks like you have some responses from a community member. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
