Hi All,
I'm tyring to catch event when windchill user login into system so I have used below API its not trriggered in WC-12.1 version
SessionUserAuditEvent.LOGIN
any new API's available?
VR
Finally I fount the listener when user dont have license assigend event is "SessionUserAuditEvent.LOGIN_DENIED_NOT_ASSIGNED_TO_LICENSEGROUP"
Not sure if this applies, but maybe check to see if the Login event is set to be recorded on your system?
