How to create WTDocument using Rest ODATA API?
Pushpak
11-Garnet
I want to create a WTDocument using windchill rest service there is an API under Document Management.
Could you please help me for the providing proper input.
The input JSON is below-
"Title": "",
"Number": "1234",
"Description": "Text",
"Name": "test",
"@odata.type": "#PTC.DocMgmt.EngDoc",
"SmallThumbnails@odata.bind": [
"PrimaryContent@odata.bind": "",
"Thumbnails@odata.bind": [
"Context@odata.bind": "Containers('OR:wt.pdmlink.PDMLinkProduct:188653')",
"Folder@odata.bind": "",
"Attachments@odata.bind": [
I am always getting "The binding link '' is malformed"  exception.
Thanks!!!
avillanueva
(To:Pushpak)
Not an expert in REST here but is this your solution?
https://www.ptc.com/en/support/article/CS375783?source=search
Thanks for response @avillanueva .
Tried this way also but still facing the same issue.
amarsingh
(To:Pushpak)
I have not been active in Windchill REST Services but at a glance, I can see a few possible problems:
  • Navigation binds like Folder should have the entity type mentioned like "Folder@odata.bind": "Folders('<folder_id>')".
  • I am not sure if you can add other Navigation types like SmallThumbnails, PrimaryContent, Thumbnails, Attachments. Check them in your metadata. But I am sure that Context and Folder are allowed & required.
This does should work
"Name": "test",
"Title": "Test1 Title",
"Folder@odata.bind" : "Folders('<folder_id>')"
