I would like to get the same folder and content representation of project container from Windchill to Navigate using ODATA services, I stuck at getting subfolders(level 2+). Please help me.
I use the following API
Windchill/servlet/odata/v6/DataAdmin/Containers('ID')/Folders?%24count=false&%24expand=Folders
However, this gives me only the first level of the folder structure not the nested folders.
Also, How to get the folder content?
many thanks,
Janakiraman
You can use below to fetch all levels
Windchill/servlet/odata/v6/DataAdmin/Containers('ID')/Folders?%24count=false&%24expand=Folders(%24levels%3Dmax)Let me know if you need any clarification on this
Hi @Janaki.Raman
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
