How to reassign new lifecycle state
RS_13475894
3-Newcomer
I have added 2 new states in Site >> Utilities >> Type and Attribute Management >> Customize Modeled Enumerations and after adding it to Site>>Utilities>> Lifecycle Template Adminitstration>> TKEPartLC, the new lifecycle is still not visible when I do reassign lifecycle for a given tkePart in windchill. It still shows the old lifecycle of TKEPartLC.
Fadel
23-Emerald I
(To:RS_13475894)
Do you get any error/warning  in logs when reassigning LC
Fede
HelesicPetr
(To:RS_13475894)
Hi @RS_13475894
How did you do it?
Have you really reassigned the LC correctly? do you see the lifecycle template change in the Lifecycle history on the object?
the number is a template iteration.
PetrH
Also check that you don't have another life cycle template with the same name at a lower level (Organization or Product/Library).
Hi @RS_13475894
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Catalina
PTC Community Moderator
PTC
