I saw below request (updating username and password of users in bulk) created 5 years ago but seems PTC still hasn't planned to implement it yet. I wonder if anyone here has done something similar in Windchill 10 or 11 and how did you do it?
Actually I don't need to update username and password, but I would like to update tons of users to a different organization at once instead of manually changing each user's organization in Participant Administration UI.
Your information and sharing are highly appreciated.
https://www.ptc.com/en/support/article?n=CS59042
You can try to use infoengine task to update these attributes of users.
such as
<%@page language="java" session="false" access="http|soap"%>
<%@taglib uri="http://www.ptc.com/infoengine/taglib/core" prefix="ie"%>
<ie:webject name="Update-Object" type="ACT">
<ie:param name="INSTANCE" data="$(@FORM[]supporting-adapter[*])" delim="!" valueSeparator="!" default="com.ptcts.Ldap"/>
<ie:param name="DBUSER" data="cn=Manager"/>
<ie:param name="PASSWD" data="ts"/>
<ie:param name="GROUP_OUT" data="updated_user"/>
<ie:param name="OBJECT" data="uid=nametestnew,ou=people,cn=AdministrativeLdap,cn=Windchill_10.2,o=ptc"/>
<ie:param name="MODIFICATION" data="REPLACE"/>
<ie:param name="FIELD" data="uid=aaa"/>
<ie:param name="FIELD" data="uid=bbb"/>
<ie:param name="FIELD" data="uid=ccc"/>
<ie:param name="FIELD" data="uid=ddd"/>
<ie:param name="FIELD" data="uid=nametestnew"/>
</ie:webject>
