I am using Windchill PDMLink Release 12.1 and Datecode with CPS 12.1.2.1
Info Engine custom tag directives not working as expected https://www.ptc.com/cs/help/windchill_hc/wc102_hc/index.jspx?id=IEUG_CustomTagDirectives&action=show
I have modified access = internal on respective task file as well as directory delegate.info level. Still, we are able to access the task file through http (i.e. info engine task runner from client browser)
Hi @GM_10490494,
Thank you for your question!
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Thanks for using the Community!
Best regards,
Hi @GM_10490494
What do you expect? Please be more descriptive. How do you define own tag? where are the files stored.
what is the task file located? what is your http address ? how do you build it?
generally if you know the http link you can access the jsp page that is stored in the Windchill location.
PetrH
To access from browser you should set access="http", if you need internal too, access="internal|http"
