Hi All,
I want to disable project email notification it should be enable only for creation of project can we able to configure it in such a way?
Basheer
@HelesicPetr
Hi @BA_10670508
I don't think it is possible to configure it.
Generally the project notification is send if the project is started not created.
I believe that this behavior could be customized somehow but not configured.
PetrH
Hi @BA_10670508
PetrH
projectlink invitation messages are sent when the project is "started". this allows the creator to do all their setup work (team, content, plan, resources, etc.) first and have the team invited to project that is ready-to-go
They are continuously sent as well - If you add a new member to the team they will get the invitation as well
