6-Contributor
May 19, 2025
Persistable Object cannot read State with View Operation Identifier
  • May 19, 2025
  • 2 replies
  • 724 views
Version: Windchill 13.0
Use Case: I am working on an InfoEngine Task that queries for multiple object types, as well as several attributes from each object, with a read-only Operation Identifier.
Description:
Dear PTC Community,
I've encountered some frustratingly strange behavior, and can't wrap my head around why this is happening.
In our I*E Task, we take a list of input objects, and create new PersistableAdapters to access the data within:
PersistableAdapter pa = new PersistableAdapter(object, null, SessionHelper.getLocale(), OperationIdentifier.newOperationIdentifier(OperationIdentifierConstants.VIEW));
For this case of Attribute  `state.state`, we process it as follows (abbreviated):
PersistableAdapter objAdapter = pa;
AttributeTypeSummary ats = objAdapter.getAttributeDescriptor(attribute);
DataSet ds = ats.getLegalValueSet();
if (ds != null && ds instanceof EnumeratedSet && loadedValue != null){
 LWCEnumerationEntryValuesFactory eevf = new LWCEnumerationEntryValuesFactory();
 EnumerationEntryIdentifier eei = ((EnumeratedSet) ds).getElementByKey(loadedValue.toString());
 if (eei instanceof ModeledEnumerationEntryIdentifier){
 ModeledEnumerationEntryIdentifier meei = (ModeledEnumerationEntryIdentifier) eei;
 String className = meei.getContext().getName();
 wt.fc.EnumeratedType cls = wt.fc.EnumeratedTypeUtil.toEnumeratedType(className, loadedValue.toString());
 return cls.getDisplay().toString();
 else{
 return eevf.get(eei, Locale.ENGLISH).getDisplay().toString();
In the resulting MethodServer logs, we catch the following error, and receive no value for `state.state`:
[ajp-nio-127.0.0.1-8010-exec-7] wt.system.out wcadmin - com.ptc.core.meta.container.common.ConstraintException: The value for State cannot be changed.
This alone is strange to me. As far as I can tell, I've followed docs and guidelines pretty well, and can't wrap my head around why this would happen with `wcadmin`. We set a read-only Operation type, but why does it think we're trying to Write?
I'd appreciate any insight the community may have, as this particular I*E Task has been a project in of itself.
Addendum:
A colleague told me to use `null` OperationIdentifier on the `pa`, and it actually worked. There were no complaints in the MethodServer logs about `state.state`. Nice, and it lets me keep working, but this seems like a band-aid solution.
Article - "Exception "com.ptc.core.meta.container.common.ConstraintException: The value for XXX cannot be changed." while updating Instance Based Attribute(IBA) using PersistableAdapter API in Windchill": https://www.ptc.com/en/support/article/CS387857
Hi @AM_9930586,
Can you use the following API and Check
PersistableAdapter pa = new PersistableAdapter(object, null, SessionHelper.getLocale(), new DisplayOperationIdentifier());
6-Contributor
June 6, 2025
Just tried it out, and no luck on pulling the State.
