Query-Links thrown NullPointerException for more than one value to object_ref parameter
AD_10574558
Query-Links webject thrown NullPointerException
This exception thrown when 2 or more id send to object_ref
Exception thrown for following inputs to Query-Links:
TYPE|DIRECTION|output_type|auto_navigate|attribute
wt.part.MasterIteration|master|FULL|false|iteration,number,masterReference
wt.part.WTPartDescribeLink|describesDoc|FULL|true|describes,name,number,masterReference
wt.part.WTPartReferenceLink|referencesDoc|FULL|true|referencedBy,name,number,masterReference
Windchill: 12, 13
Exception:
Nested exception is: java.lang.NullPointerException
at com.ptc.core.adapter.server.impl.AbstractWebject.addTypeInstance(AbstractWebject.java:925)
at com.ptc.core.adapter.server.impl.AbstractWebject.addTypeInstance(AbstractWebject.java:901)
at com.ptc.core.adapter.server.impl.QueryLinksWebjectDelegate.invoke(QueryLinksWebjectDelegate.java:497)
at com.ptc.core.adapter.server.impl.WebjectDelegateFactory.invokeDelegate(WebjectDelegateFactory.java:434)
at jdk.internal.reflect.GeneratedMethodAccessor1027.invoke(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at wt.method.WTAdapterImpl.processWebject(WTAdapterImpl.java:840)
at wt.method.WTAdapterImpl.processRequest(WTAdapterImpl.java:537)
at com.infoengine.procunit.adapter.Adapter.send(Adapter.java:199)
at com.infoengine.SAK.ObjectWebject.invoke(ObjectWebject.java:319)
Webject:
<ie:webject name="Query-Links" type="OBJ">
<ie:param name="INSTANCE" data="<%=com.infoengine.au.NamingService.getVMName()%>" valueSeparator=";" delim=";" />
<ie:param name="TYPE" data="wt.part.MasterIteration"/>
<ie:param name="object_ref" data="VR:wt.part.WTPart:4655178:591698760-1730379217407-1158614409-186-30-168-192@vinw16wc30186.eqvm.local#VR:wt.part.WTPart:4655819:591698760-1730379217407-1158614409-186-30-168-192@vinw16wc30186.eqvm.local" valueSeparator="#" delim="#"/>
<ie:param name="DIRECTION" data="master"/>
<ie:param name="output_type" data="FULL"/>
<ie:param name="auto_navigate" data="false"/>
<ie:param name="attribute" data="iteration,number,masterReference" delim=","/>
<ie:param name="group_out" data="objects"/>
</ie:webject>
at wt.adapter.query.QueryLinksWebjectDelegate.navigate(QueryLinksWebjectDelegate.java:549)
at wt.adapter.query.QueryLinksWebjectDelegate.navigate(QueryLinksWebjectDelegate.java:465)
at com.ptc.core.adapter.server.impl.QueryLinksWebjectDelegate.invoke(QueryLinksWebjectDelegate.java:265)
at jdk.internal.reflect.GeneratedMethodAccessor307.invoke(Unknown Source)
<ie:param name="TYPE" data="wt.part.WTPartDescribeLink"/>
<ie:param name="object_ref" data="VR:wt.part.WTPart:4751222:591698760-1730379217407-1158614409-186-30-168-192@vinw16wc30186.eqvm.local" valueSeparator="#" delim="#"/>
<ie:param name="DIRECTION" data="describesDoc"/>
<ie:param name="auto_navigate" data="true"/>
<ie:param name="attribute" data="describes,name,number,masterReference" delim=","/>
</ie:webject>
The direction should be either describes or describedBy
e.g. link from the part to doc
(the part is described by the doc)
	<ie:param name="instance" data="<%= wtadapterVMName %>" valueSeparator=";" delim=";" default="Windchill" />
	<ie:param name="object_ref" data="VR:wt.part.WTPart:605752690"/>
	<ie:param name="DIRECTION" data="describedBy"/>
</ie:webject>
 e.g. link from the doc to the part
(the doc describes the part)
	<ie:param name="object_ref" data="VR:wt.doc.WTDocument:1249683439"/>
	<ie:param name="DIRECTION" data="describes"/>
</ie:webject>
Hi @AD_10574558
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
Catalina
PTC Community Moderator
PTC
</ie:webject>
</ie:webject>
AD_10574558
(To:rhart)
Hello @rhart, Thank you very much for the response!
 Similar to "DescribeBy" attribute, "DescribeDoc" reference attribute also shown in logical attribute report, that's why I used it to fetch document form part
Not sure why Windchill is still showing it, as it looks like it is deprecated or not working for direction parameter. If I missed anything or any understanding please let me know.
Can you please also let me know why wt.part.MasterIteration is not working?
