QuerySpec with specific WTDocument soft type and IBA Value
Vishwa_RADDI
Hi All,
I have custom IBA on one of the WTDocument softype, I want to retrieve all the document with this IBA value. Please suggest how to add searchCondition in QuerySpec?
Vishvanatha
Hi @Vishwa_RADDI
I've created a method to do what you need.
searchIBA is a name of IBA attribute
searchVALUE is a search key what you need to search
searchClass is a object class what you want to search example> WTDocument.class or WTPart.class atc.
public static List searchObjectByIBAValue(String searchIBA, String seachVALUE, Class searchClass)
	List retValue = new ArrayList<>();
	QuerySpec queryspec;
	try
		queryspec = new QuerySpec();
		queryspec.setAdvancedQueryEnabled(true);
		int indexObjectEPM = queryspec.appendClassList(searchClass, true);
		int indexObjectSTRV = queryspec.appendClassList(StringValue.class, true);
		int indexObjectIBA = queryspec.appendClassList(StringDefinition.class, true);
		SearchCondition condition17 = new SearchCondition(
						searchClass, WTAttributeNameIfc.ID_NAME,
						StringValue.class, "theIBAHolderReference.key.id");
		condition17.setOuterJoin(SearchCondition.LEFT_OUTER_JOIN);
		queryspec.appendWhere(condition17,
													new int[]{indexObjectEPM,
																	indexObjectSTRV});
		queryspec.appendAnd();
						StringValue.class, "definitionReference.key.id",
						StringDefinition.class, WTAttributeNameIfc.ID_NAME);
													new int[]{indexObjectSTRV,
																	indexObjectIBA});
		CompositeWhereExpression andCondition = new CompositeWhereExpression(LogicalOperator.AND);
		andCondition.append(new SearchCondition(StringDefinition.class,
																						StringDefinition.NAME,
																						SearchCondition.LIKE,
																						searchIBA), new int[]{indexObjectIBA});
		queryspec.appendWhere(andCondition, new int[]{indexObjectIBA, indexObjectIBA});
		andCondition.append(new SearchCondition(StringValue.class,
																						StringValue.VALUE,
																						seachVALUE), new int[]{indexObjectIBA});
		queryspec.appendWhere(andCondition, new int[]{indexObjectSTRV, indexObjectSTRV});
		andCondition.append(new SearchCondition(searchClass,
																						"iterationInfo.latest",
																						"TRUE"), new int[]{indexObjectEPM});
		queryspec.appendWhere(andCondition, new int[]{indexObjectEPM});
		queryspec.appendOrderBy(new OrderBy(new ClassAttribute(searchClass, "master>number"), false), new int[]{0});
		queryspec.appendOrderBy(new OrderBy(new ClassAttribute(searchClass, "versionInfo.identifier.versionSortId"), false), new int[]{0});
		QueryResult queryRes = PersistenceServerHelper.manager.query(queryspec);
		if (queryRes.hasMoreElements())
			while (queryRes.hasMoreElements())
				Object[] obj = (Object[]) queryRes.nextElement();
				retValue.add(obj[0]);
		System.out.println("SearchObjectByIBAValue fnished.");
	} catch (WTException e)
		e.printStackTrace();
	} catch (WTPropertyVetoException e)
	return retValue;
PetrH
Hi @Vishwa_RADDI
	try
																	indexObjectSTRV});
																	indexObjectIBA});
																						StringValue.VALUE,
	return retValue;
PetrH
