Remote access invoke issue while executing Windchill API's from client machine using Eclipse.
- July 26, 2023
- 1 reply
- 1581 views
I am using Windchill PDMLink Release 11.0 and Datecode with CPS N/A
Referred to article CS254321 for RMI.
Here are the errors that I faced
java.lang.NoClassDefFoundError: sun/rmi/transport/proxy/RMISocketInfo
at java.base/java.lang.ClassLoader.defineClass1(Native Method)
at java.base/java.lang.ClassLoader.defineClass(ClassLoader.java:1013)
at java.base/java.security.SecureClassLoader.defineClass(SecureClassLoader.java:150)
at java.base/jdk.internal.loader.BuiltinClassLoader.defineClass(BuiltinClassLoader.java:862)
at java.base/jdk.internal.loader.BuiltinClassLoader.findClassOnClassPathOrNull(BuiltinClassLoader.java:760)
at java.base/jdk.internal.loader.BuiltinClassLoader.loadClassOrNull(BuiltinClassLoader.java:681)
at java.base/jdk.internal.loader.BuiltinClassLoader.loadClass(BuiltinClassLoader.java:639)
at java.base/jdk.internal.loader.ClassLoaders$AppClassLoader.loadClass(ClassLoaders.java:188)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:521)
at java.base/java.lang.Class.forName0(Native Method)
at java.base/java.lang.Class.forName(Class.java:391)
at java.base/java.lang.Class.forName(Class.java:382)
at wt.boot.WTRMIMasterSocketFactory.lambda$loadClass$9(WTRMIMasterSocketFactory.java:597)
at java.base/java.security.AccessController.doPrivileged(AccessController.java:571)
at wt.boot.WTRMIMasterSocketFactory.loadClass(WTRMIMasterSocketFactory.java:597)
at wt.boot.WTRMIMasterSocketFactory.<clinit>(WTRMIMasterSocketFactory.java:126)
at wt.manager.RemoteServerManager.getRegistry(RemoteServerManager.java:703)
at wt.manager.RemoteServerManager.acquireServerManager(RemoteServerManager.java:527)
at wt.manager.RemoteServerManager.getServerManager(RemoteServerManager.java:506)
at wt.manager.RemoteServerManager.remoteInvoke(RemoteServerManager.java:442)
at wt.manager.RemoteServerManager.getServer(RemoteServerManager.java:278)
at wt.manager.RemoteServerManager.getServer(RemoteServerManager.java:262)
at wt.method.RemoteMethodServer.getMethodServer(RemoteMethodServer.java:1018)
at wt.method.RemoteMethodServer.invoke(RemoteMethodServer.java:616)
at mrk.rmi.RmiClient.main(RmiClient.java:38)
Caused by: java.lang.ClassNotFoundException: sun.rmi.transport.proxy.RMISocketInfo
at java.base/jdk.internal.loader.BuiltinClassLoader.loadClass(BuiltinClassLoader.java:641)
... 28 more
Attached the code I'm using for remote access invoke.
