3-Newcomer
February 27, 2025
Retrieving datas using odata REST Api
  • February 27, 2025
  • 689 views
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.1.0
Windchill odata rest api:
Given an EPMDocument ID ( ex: OR:wt.epm.EPMDocument:140542976) , how do I get the ID of EPMDocuments that reference it using the ASSTORED or LATEST navigation criteria?
Fadel
23-Emerald I
March 12, 2025
Bonjour Alain,
The Nav criteria are filters used to resolve  BOM Components .
The reference EPM document do no use filters as far as I know :
take a look at https://www.ptc.com/en/support/article/CS340518 ,
BR,
Fadel
Buiꓘa
3-Newcomer
March 25, 2025
In fact I want retrieve the EPMDcoument which uses the given one. Ex: Given an EMPDocument representing a Creo part, I want retrieve all CREO assemblies which use it.
Fadel
23-Emerald I
March 25, 2025
is there a requirement to use Rest , this can be done OOTB using alias attributes
On the EPMDoc type create an Object Refeerence alias attribute with mapping masterReference@wt.epm.EPMDocumentMaster~uses@wt.epm.structure.EPMMemberLink~usedBy^wt.epm.EPMDocument
This will show the parents are links on the info page :
and you can query the attribute dierctly in Rest .
Buiꓘa
