I developed an application in C# that retrieves information through a REST API from attachments, references, WTUser, and representations based on the EPMDocument idA2A2, except for WTUser. Later, I started encountering timeout issues with these APIs. The interesting thing is that when I switch the method server console to full screen, the timeout problem disappears, and this only happens with the APIs I mentioned. There are no issues with connections like WTPart. Is the reason for this that I am trying to process these APIs consecutively, or is there an issue with a setting related to EPMDocument in Windchill? Because, as I said, when I make the method server full screen, the timeout problem goes away. Should I try restarting the server?
Hi @ozclkonur
Thank you for your question!
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
Hi @ozclkonur
What do you mean Method server full screen? Do you talk about command line utility CMD where the method server is run?
If so, be sure that you did not pause the process by selecting a line or char in the command line window.
PetrH
