Update Stamp via WRS REST API
Version: Windchill 12.1
Use Case: I need to retrieve documents that were set to released in the past 24 hours.
Description:
I am looking to find documents that were set to released in the past 24 hours. I am doing this via InfoEngine by querying for objects with an UpdateStamp greater than a date/time stamp for yesterday.
In InfoEngine updateStamp and modifyStamp are returned and represent two different use cases. I need updateStamp. Below is the values I am seeing come back from InfoEngine
<thePersistInfo.updateStamp>2024-05-24 13:01:13 EDT</thePersistInfo.updateStamp>
<thePersistInfo.modifyStamp>2024-05-16 09:49:15 EDT</thePersistInfo.modifyStamp>
The DynamicDocument Rest API returns LastModified, which seems to align with modifyStamp from InfoEngine, but I am not seeing a value come back from the REST API's for UpdateStamp.
"LastModified": "2024-10-25T12:56:32-04:00",
I am able to get the documents that were modified after a given date timestamp with the following query.
LastModified gt 2024-10-24T15:39:10-04:00
Is there a way to query against the updateStamp field available from InfoEngine via the REST API's?
