Workflow expression "cannot find symbol" of compiled custom class
Dobi
Version: Windchill 13.0
Use Case: I wrote/compiled some code to collect and send to a messaging queue a part BOM. Part of this code has two custom classes (BOM, BOMLines). The return of my method is a List but the workflow expression says it "cannot find symbol" for my BOM class.
Description:
In the workflow expression I have:
java.util.List<ext.comp.BOM> myBOM = ext.comp.getBOMSfromECN(cn);
ext.comp.Messages.sendToERP("BOM from ECN: " + myBom.toString());
Check syntax in the workflow doesn't like the ext.comp.BOM...
WfExpression_88956210.java:72: error: cannot find symbol
                java.util.List<ext.ursa.BOM> myBOM = ext.ursa.getBOMSfromECN(cn);
On the server I have a BOM.java and BOM.class. Originally I had both of my custom classes in my main code but a compilation error said these would have to exist as standalone .java, so they do.
How can I use my custom class in a workflow expression?
package ext.comp;
import java.util.*;
public class BOM {
    private List<BOMLine> lines;
    private String parentPN;
    private String parentRev;
    public BOM(List<BOMLine> lines, String parentPN, String parentRev) {
        this.lines = lines;
        this.parentPN = parentPN;
        this.parentRev = parentRev;
    public void setLines(List<BOMLine> children){
        this.lines = children;
Dobi
(To:joe_morton)
@joe_morton  I did yes... what turned out to be the issue was more basic (Java basic).
The method was not static so I needed to invoke it differently. First create a new instance and then invoke the method:
ext.comp.getBOMS gb = new ext.comp.getBOMS();
java.util.List<ext.comp.BOM> myBOM = gb.getBOMSfromECN(cn);
Alternatively, if getBOMSFromECN is a static method, then I can invoke it like I had it:
PTC Tech Support was actually support prompt and extremely helpful in getting this sorted out.
Dobi
(To:joe_morton)
