I have written a separate xconf for data utility and I have register this custom xconf file in site.xconf as shown in below image
and this my custom xconf file
after I ran the xconfmanager -p the properties are not being updated in file.
Sorry, a dumb question ..but did you restart MS after the xconf command?
Hello @SB_10904295,
It looks like you have a response from a community member. If you are in position to respond, please do so so that you can get an answer. Or if it helped to answer your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
Hi @SB_10904295
I understand the xml structure, but does this structure work in Windchill? have you seen that anywhere used? because I've never used this structure
I define each option separately with all other attributes.
so I would try to define all options separately.
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE Configuration
SYSTEM "xconf.dtd">
<Configuration xmlns:xlink="http://www.w3.org/1999/xlink">
<Service context="default" name="com.ptc.core.components.descriptor.DataUtility"
targetFile="codebase/service.properties">
<Option cardinality="duplicate" order="1" overridable="true"
requestor="java.lang.Object"
selector="duMySelctor"
serviceClass="cz.aveng.MyOwnD.DataUtility"/>
</Service>
selector="duMySelctor2"
serviceClass="cz.aveng.MyOwnD.DataUtility2"/>
</Service>
</Configuration>
PetrH
