`getLinkOtherSideObjects` method while working on a configMastersLink
SriTalatam
In `configurableLinkRoleATable.jsp`, the method `getRoleBLinkObjects` from the class `GetOtherSideObjectsForConfigurableLinkCommand` is typically used to display the “side B” parts of a config link.
Has anyone experimented with the related method `getLinkOtherSideObjects` in the same class and if so, what arguments did you pass? I’m curious whether it can be leveraged to show the *opposite side* of the link (e.g. Part B when I’m on Part A, and vice versa).
My use case as mentiond above, involves a **custom ConfigMastersLink** where there isn’t a strict parent/child relationship — it’s simply two parts associated with each other.
I tried like this, but couldn’t determine what other string parameters (besides `roleAObject` or `roleBObject`) are valid:
<%-- Get a component model for our table --%>
<jca:getModel var="tableModel" descriptor="${configurableLinksRoleBObjectsTable}"
serviceName="com.ptc.windchill.enterprise.object.commands.GetOtherSideObjectsForConfigurableLinkCommand"
methodName="getLinkOtherSideObjects">
<jca:addServiceArgument value="${commandBean}" type="com.ptc.netmarkets.util.beans.NmCommandBean" />
<jca:addServiceArgument value="roleBObject" type="java.lang.String"/>
</jca:getModel>
Hi @SriTalatam,
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Anurag
