remove wtpart from CN with api
LS_9572212
3-Newcomer
Version: Windchill 12.1
Use Case: Hi, I want to delete the Parts from Change notice(Change activity), Problem report & Change request. later want to clean the Part data from windchill
Description:
Hi @LS_9572212,
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
Catalina
PTC Community Moderator
PTC
@LS_9572212
I agree with @Catalina , you need to spec out exactly how this should work.
For example,
given a WTPart version I want to remove it from all the change objects you mentioned.
Or
given a change object I want to remove all WTParts from that object
Or
I want to remove all WTParts database wide from all change objects.
Your post is quit ambiguous. You really need to spec out EXACTLY what you are doing in a use case and a description of EXACTLY he the code works starting with input arguments.
David
windchill.developer@yahoo.com
