Error during schema creation . error while installing windchill 11.0
Gagan
Hello All
I am getting this error while installing WIndchill 11.0 . any one came across with this error before ?
I have attached one PSI log which is from the location C:\ptc\Windchill_11.0\PSI\installer\logs .
I have copied the log from the log file  "PTCSOLNINSTALLER_PtcInstall" to a separate file and attached here , since the original log file is 120 MB
Regards
2 REPLIES 2
Arshad
(To:Gagan)
Hi
I found this article matching the error message in your logs.
https://www.ptc.com/en/support/article?n=CS247845
It seems like you have created Windchill schema in database prior to the installation. If so please try the steps from article to complete the installation.
Gagan
(To:Arshad)
Hello Arshad
Thanks for your reply
Yes i created the schema before PSI installation , created files BLOBS.sql,INDZ.sql and WCAUDIT.sql and I selecetd the option as per the pic (selection) while installation. later while installing , installation stopped @ 69% with the error "Windchill Loader failed "  What this error mean ?
I have also attached log file .
Regards
