I'm in the process of testing an upgrade to Windchill 11. In my test environment that is hosting the test Windchill 10.2 environment, I went backwards to a point in time on my virtual servers that I needed to do something from again. However, Windchill will not start up now. I get the following error in my logs. Any ideas as to how to fix? I've gone backwards before and have never had an issue.
(wt.services.servicesResource/21) wt.services.ManagerException: Unable to start manager: "wt.audit.AuditService" with implementation class: "wt.audit.StandardAuditService"
Nested exception is: wt.services.ManagerException: Could not initialize Auditing service.
Nested exception is: wt.util.WTException: (wt.federation.PrincipalManager.PrincipalManagerResource/CONFIG_ERROR_INCORRECT_NAMING_PROVIDER) com.infoengine.util.IEException: Info*Engine configuration error - The default Directory Service Provider URL and/or Service Search Base could not be retrieved from Info*Engine properties. Contact your system administrator.
It ended up that my LDAP and filevault information got all messed up even though I have not done a rehost in a long time. I was able to find a good export of my LDAP on the server and was able to import it and that fixed it.
If you haven't already checked, look for ldap URL in ie.properties . Did the IP address or hostname change ?
