Hi
We are using PTC Integrity 10.6 0.7337, API 4.14.7337
I am using batch files to send CLI commands.
I have two computers to test. An English Windows 7 machine and a German Windows 7 machine.
In my tests regional characters are not handled correctly by the CLI command, although I set the code page in the batch file.
I am asking whether are CLI commands considering the default code page specified in the batch file?
1) Create a batch file, saved as an ANSI bat file, like this (simplified command syntax, not all arguments are provided for simplicity)
chcp 1252
si rlog --project=#t:/mks/Test1/GermanProjectNameäöüß
When I run it, I get the error
*** MKS125443: The subproject GermanProjectName��?�/project.pj does not exist (anymore).
2) Create another batch file, this time saved as an UTF-8 bat file (simplified command syntax, not all arguments are provided for simplicity)
chcp 65001
si rlog --project=#t:/mks/Test1/SomeProject äöüß.txt
The file ��?�.txt is not a current or destined or pending member or a subproject of t:/mks/Test1/SomeProject/project.pj
So, the regional characters are not interpreted correctly by the CLI Command
Thanks !
Code page 1252 is the default for Windows and does not recognize the regional characters. Have you tried code pages 850 or 1250?
Two conditions must be met
1. Make sure the batch file is saved as OEM (see screen capture attached). This is very important!
2. Make sure the code page set in the batch file matches that of the characters being used for project and member names
For German letters it is 850 so using chcp 850 works now fine.
