Hello Everybody,
I found in Integrity documentation that it should be possible to run automatically tests.
In the help, it is mentionned that is is possible to find additional information in "Integrating Integrity 2010 for Automated Test Execution" document available from support.
I am currently running Integrity 10.6 and I was not able to find the above mentionned document.
Thanks in advance for any support on finding this documentation or any other documentation that could help to understand how to use Automated Tests.
Marc.
Hi Marc,
the topic to look for is ATEF. Go to the PTC support page, and search for this word.
It stands for Automated Test Execution Framework.
If you need anything on top, just let me (us) know.
Volker
Hi Marc,
Volker
Hello Volker,
Thanks a lot for your answer, but I was not able to find anything relevant for Integrity 10.6
So if you have any link, I would be much interested.
Cordialement/ Mit freundlichen Grüßen/ Best regards
Marc.
Hi Marc,
the current material is the one you may have found. I am not aware of any major change in the ATEF process itself.
Volker
