Bug tracking with PTC Integrity
MarcosSuarez
We use Windchill as PDM and Subversion as Tool for our Software designer.
Now we want to introduce a Bug tracking Software.
Actually the Idea was to introduce Redmine in our company. But we also plan to change to Integrity between the next 2 Years.
Now the question is, has Integrity also a Bugtracking tool like Redmine or bugzilla?
greetings
Marcos
1 ACCEPTED SOLUTION
KaelLizak
(To:MarcosSuarez)
Hello Mr. Suarez,
We use Integrity internally for defect tracking. You may want to contact our Services group or your Account Manager to see if they have an existing solution to that problem.
Alternatively, you could roll your own bug-tracking solution to meet your specific needs.
Kind Regards,
Kael Lizak
Absolutely.
Integrity allows you to invent your own defect process from the ground up with your desired fields, workflow, and many customizable behaviors. Bugzilla and the like are good starter kits, but Integrity is far more robust and customizable.
That said, I haven't any idea how well it would fit with subversion as the versioning tool. Naturally, Integrity is built to work with its own internal versioning, formerly known as "Source Integrity".
We use Integrity for both versions and defects.
KaelLizak
(To:MarcosSuarez)
Hello Mr. Suarez,
Kind Regards,
Kael Lizak
