C API Response not working
ubischoff
I'm using the C API 4.15 with Integrity 10.7 and Visual Studio 2010.
Creating the integration point, the sesson an the command works without erros.
With "mksCmdRunnerExecCmd" I get a response pointer.
Working with this pointer I always get  = null.
- mksResponseGetResult(MyResponse);   = null
- mksResponseGetFirstWorkItem  works, but  mksWorkItemGetResult(workItem)  = null
In all cases the error code  = 0
In the example in  "Always Null response"  there is the same problem.
The Java API  and the command line works fine without problems.
Can anybody help ?
Is there any logging possibility to find out the problem ?
Uwe
Are you supplying hostname, port, user, and password with every command? That was something I ran into. I thought I only needed to specify it when creating the session.
The problem is already at the first command.
I found the problem.
I was wrong. I have to be careful what functions are possible with the received respond.
