Hi all,
I'm trying to execute a query via the webservice. I can excute the query using the client, it is visible and owned by my user and contains only one column ID.
I transfer the following SOAP using HTTP-post:
<SOAP-ENV:Envelope
xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/"
SOAP-ENV:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
<SOAP-ENV:Body>
<m:getItemsByNamedQuery xmlns:m="http://webservice.mks.com/2009/Integrity">
<arg0>
<Username>myuser</Username>
<Password>password</Password>
<InputField>ID</InputField>
<QueryName>testq</QueryName>
</arg0>
</m:getItemsByNamedQuery>
</SOAP-ENV:Body>
</SOAP-ENV:Envelope>
The answer of the server is a fault-message:
<env:Envelope xmlns:env='http://schemas.xmlsoap.org/soap/envelope/'><env:Header></env:Header>
<env:Body>
<env:Fault xmlns:env='http://schemas.xmlsoap.org/soap/envelope/'>
<faultcode>env:Server</faultcode>
<faultstring>Unable to retrieve items via query "null".
</faultstring>
<detail>
<ns1:MKSException class='java.lang.NullPointerException' implication='Unable to retrieve items via query "null".' xmlns:ns1='http://webservice.mks.com/2009/Integrity/fault'/>
</detail>
</env:Fault>
</env:Body>
</env:Envelope>
It seems that the server does not recognize my QueryName-tag. Do you have an idea? Is the request SOAP-message correct, or did I miss something there?
Any help would be highly appreciated,
kind regards
Matthias
Some ideas:
- Does the Query "testq" exist and is it visible?
Maybe you try to "identify" the query more precisely, comparable to the Query usage in computed fields
(e.g. "myuser:testq" )
- Does the Query "testq" return any items? (There is a know issue for queries with empty result sets, where the webservice retruns a null pointer exception) As far as I know there was recently a Hotfix provided for that. Please ask PTC Support for details.
HTH Matthias
Hi, thanks a lot for these hints.
The query exists, is visible to my user, and returns around 10 IDs. I tested using "myuser:testq", with and without quotes, with and without "myuser:"-prefix, but the result is always the same.
Using im.exe, i can see the query definition if I login with the user "myuser" that I provide in the SOAP request.
Matthias
