Can't create traces from requirements of a current document to requirements of a baselined document
fantony
I use Integrity 10.4 and I would create traces between a current document and another that is already baselined.
Is is possible to do that?
If no, how do you manage the fact that it is better to trace to a baseline document (because nobody is modifying it), and the person who has baselined his document can continue to work on the next document version?
KaelLizak
(To:fantony)
Hello Frederic,
My initial investigation suggests that is not possible with the "out-of-the-box" ALM solution configuration. It could certainly be hacked with certain fields becoming editable, but I suspect that is not your goal here.
Because every trace relationship has a suspect flag on it, when one end of the trace is modified, the other end is marked suspect, requiring a review of the related item in the trace to confirm a change has not occured, or to make the required change to the unchanged item.
Kael
Kind Regards,
Kael Lizak
KaelLizak
(To:fantony)
Hello Frederic,
Kael
Kind Regards,
Kael Lizak
