HI.
I've just made a java program fetching files from Integrity CM system and it works good on the Window OS .
But I've found it not working without operating the client program on the Linux OS, where the program will actually be running, and the client has not been installed on.
So, here's my question.
1) Is there Any way of Creating/resynchronizing sandbox without Client, using API?
-I've been using localIntegrationPoint so far, for the system has sent me "Sandboxes cannot be created or imported directly on the Integrity Server." messages.
2) What should I do to install client on my linux OS?
-I'm not in charge of the Integrity system, so I got no clue what should I do. Should I tell the manager in charge to install the client on Linux?
Any ideas or tips will be helpful. Thanks in Advance.
It's not possible to create or work with a sandbox without a client installed. The API needs to connect to a client rather than the server.
If you want to work with sandboxes then yes, you should tell the manager to get the Integrity Client installed on Linux.
Thank you so much, awalsh.
After discussions with the manager, it is decided for me to install a client on our linux OS, which is Cent OS 7.4(64bit), and I found the PTC doesn't support a client for it officially.
Nevertheless, I've been trying to install 'Integrity-10-9-Client-Linux32' on the system, following
'/ClientUserGuide_Integrity_10_9.pdf' guide documentation and 'https://www.ptc.com/en/support/article?n=CS124168'.
And now, I'm facing with another error messages when try launching the client, saying that
"./si: Attempt to launch Integrity Client timed out. To solve this please try the following:
- Verify that the user you are logged in as has read and write permissions to the Integrity Client install directory."
I've found a similar issue, "https://community.ptc.com/t5/Integrity-Questions/Attempt-to-launch-MKS-Integrity-client-Timed-out/m-...", so I've double-checked my path '/home/user/Integrity/IntegrityClient10/bin' be registered, but still got the same message.
Is there any problems you've found from What I've done?
Thank you again.
There are several reasons one can get the "Integrity Client timed out" error message. The most common reasons I've seen are:
