Display ViewSet in the client with CLI
BiFi
I have to make a viewset available ( as in being displayed) from the CLI.
I use integrity fetchviewset to import the viewset and make it available in the client menu ViewSet -> Open. This command makes the viewset to be displayed on the list that appears in the client from the menu ViewSet -> Open and the user has to select it and actually open it for display. But I want to skip this user action and make the viewset to be displayed when he opens the client, without him having to actually open the viewset "manually". Is that possible? I could not find this in the documentation.
I am using PTC 10.4 client.
Thanks for any help with this!
KaelLizak
(To:BiFi)
Just to make sure I understand this: You want to use a CLI command to update and select what ViewSet will be open the next time any user on a given workstation opens a client?
If that is the case, I am not aware of such a command. Please contact PTC Integrity Support if you wish to have such an enhancement request created.
Kael
Kind Regards,
Kael Lizak
BiFi
(To:KaelLizak)
Thank you very much for your reply and sorry for the delay in my answer.
I managed to get in contact with PTC and received an "official" answer that this is not possible via CLI; so there is no command to make the viewset be displayed when the client opens.
Maybe they will implement it in the near future...
Bianca
