Duplicate field value in Trigger
DanR.
I have an Integer field created (Integer_fld) and would like to create a trigger that checks for duplicate values for previous created items items.
I tried a script from a previous discussion, but could not make it work. I thought I would start a new discussion for this.
EXAMPLE:
List of Items
ID State Integer_fld Txt_fld
100 Initiate 10023 Some text here...
101 Initiate 10024 Some more text here...
I create a new Item ID 102 and for the Integer_fld I enter 10023. When I try to save it I would like to see an error message stating it is a duplicate. ID 100 has the same value in the Integer_fld.
Thank you,
Dan
mrump
(To:DanR.)
Hi Daniel,
there is another post that already covered this problem
Re: Duplicate Checking in Trigger
Can you specify whether your current problem is different?
HTH Matthias
DanR.
(To:mrump)
Matthias,
I started a new discussion because the script from that discussion did not work for me. I tried the one attached to the discussion. I'm simply trying to compare an Integer field of a new issue compared to all existing issues. The comparison would check for duplicate and if there was an error message would be displayed. This would obviously be a pre-event trigger.
DanR.
(To:DanR.)
I thought this would be easy and someone might have a workable solution. I believe my use case example provides enough information.
I'm assuming that the problem here is that this code compares strings and you are looking to compare integers.
this:
queryBuf.append('(');
queryBuf.append("field[");
queryBuf.append(singletonField);
queryBuf.append("]=");
queryBuf.append(currentValue);
queryBuf.append('"');
queryBuf.append(')');
Produces a query that reads: if (field[ExistingStringValue]="InputStringValue") ...
Working with integers, I'd use something more like: if (ExistingIntValue.equals(InputIntValue)) ...
Try rewriting the query building lines to work with integers instead of strings and it should work for you.
